Normals issue after "set to face"
I was messing around with the normal functions and tryed “set to face”, and after a little soften I realised my normals were kinda weird, but i wasn’t sure so I kept working and forgot about it… but when I loaded back a previous version of my object I realised something was definately worng with the normals of my new object… I tryed to fix them without success and now I’m stuck with this object and crappy normals… any help welcome… TIA
Umm run a normals conform run set to face (wich will make your object facetted), thend smooth with the angle you need! Does it still look wierd?
If so then make sure all the internal vertexes are connected (no overlaps), Set a different smoothing value. Also a good way to get a clue is to set the normal view on with per vertex info.
I tryed every single function in the normal box AND in the bonustools (they have a vertex normal thingy)… No luck! So I tryed to export my object to an old file format like the good old OBJ to get rid of any funky normal info, and,… It didn’t worked! But then I tryed to do an average normal on a small area of this object and shazzam! all my normals were back to , well normal… Same operation on the non-obj object does nothing! I guess I just got lucky… I’ll never touch set to face again!
Yeah well most peolple asum set to face doing something that its NOT doing… but thenagain that applies to everything! Espesialy in maya.
