Now this is strange
OK - heres a weird one - XSI on my system runs just fine - problem though - when the viewport is maximised - it chugs along at a painfull rate - this should not happen to start with, secondly, it only happens at 1600 by 1200 - a slight change in res makes the problem vanish… i however like to work in this res.
what on earth is going on - This happens with my geforce 2 card, and an older oxygen card aswell ??? - hmmmmmmm.
My guess is that the card’s fill rate maxes out in the large resolution. This card was built for open GL in games and most of them dont ned to run in such a high res.
On a wildcat 4110, I can run 1920*1200 no problems, of course there is a slowdon but not considerable.
Cheap cards are getting fast but still can’t match high-end.
Santiago Batiz-Benet
Z3D
Animation & Design
Seattle WA USA
  • as i stated - it also happens with an older oxygen card -
  • as i did not state - this problem does not occur in softimage 3d - 3.9 - absolutely no problems there - it takes around thirty to forty nurbs spheres to even drop frames - at 1600 by 1200!
  • on the topic of games - I run mdk 2 at 1600 by 1200 - the same with quake three - yes we do run them at that res at 30 frames per second.
  • Sorry - King, what you are saying is just not true - I am pretty stedfast on the whole highend cards buisness - it is a crock of crap - I used to use an oxygen rpm - then a gmx - and neither go anywhere near as fast as a stupid little geforce 2 - the oxygen cards cost a fortune - and still do.
Of course wildcat is another story - I’m fairly certain wildcats “fillrate” is nothing spectacular - the wildcat is the best for other reasons..
this is a problem beyond basic number crunching -
Your thing about the GTS having bad fill rate is Absolute CRAP, the geforce 2 can do 800 megapixels per second. it can eat your wildcat for breakfast, lunch and dinner (in terms of fillrate). I also run quake III at 1600*1200 and get around 40 fps with all details settings maxed out. I’m using an elsa Gladiac. do you have the latest drivers from www.reactorcritical.com ? driver version 6.18 solved alot of my problems
I’ve got the detonator 2 - drivers from nvidia, I run a hercules 3d prophet 2 - gts.
I’ll have a look at reactor critical - thanks.
