greetings!
im trying to create a toon shader like the nprs for Maya...
im not using the regular one because the lens shader is so slow for me...
im new to the render tree and so id like to ask for some help:
i need a node like maya's facing ratio sampler and i found it in Incidence(camera)...
now i have to find a node similar to the Condition(if field one is greater or equal than field 2 then if true do something,false do somthing else...
im also searching for the equivalent of the light clamp
and so on....
thanks for your time
regards.
