I know this is way late and you have probably already figured it out, but when you create a roto node it is only generating an alpha by default. In the output drop-down, change it to rgba and you will be able to see the color. In general you don't want to do this, as a roto node is intended to create a mask and you should only be using the alpha anyway.
