Nuke to Maya 3D Camera Track
So I'm having a problem getting my camera to line up with my footage I took. I have a couple of points to get tracked, I cleaned it up, set a distance between my two trackers to get the scale down and exported it into Maya as an .fbx with the default red measurements set to MM. When I set up a plank of wood for the bench geometry that I have in the scene the geometry and the locators/trackers move all around the scene in bigger motions than the camera in the sequence. I've been messing with scaling the funtions and everything but nothing seems to be working out.
I also noticed that the depth of field in nuke and maya is keyed and animates while the camera moves and think that this is keeping it from lining up correctly. Is there anything I can double check or do if this seems like a common fluke that occurs? Thanks. If you need files or images let me know.
Nevermind, got it working. I downloaded a gizmo and got it to export as an .ma file and its working like a beauty.
