Nuked House (WIP)
Hello,
This is a work in progress of a house being nuked. I
Nice job.
I wouldn’t worry about intersections, there is a lot going especially once you add the smoke and other effects as you state. If you are paranoid that someone will notice, wait until you have all your effects added. No sense in fixing an intersection that gets covered up anyway.
The only thing that stands out to me is the posts on the front porch. They seem to shear off leaving stumps that slide over the ground. I would expect them to either break off leaving the “stumps” in the same place, or they would tip over and pull out of the ground.
Just a thought.
Again, great work.
Urp
In addition to what Urp said, I notice that everything breaks off into conveniently square little peices. While I don’t have any experience in the area I doubt a nuclear bomb would be that clean. :-7
Overall, very cool.
Hope this helps.
-James
BEAUTIFUL!
I agree with the previous two posts, in addition to this, I’d expect to see a couple secondary explosions from gas mains, whatever to happen a milisecond or so after the initial blast, you may want to animate now anticipating that. Overall feel of the impact force is right on, you have a good eye for dynamic motion. Texturing, effects, and compositing is gonna be a beast, but it’ll be a GREAT piece when you’re done!
Very nice to see dynamic animation on the boards!
–Jo
Hi!
Along the lines of what was said about all the pieces being too uniform…
Another thing you could do is to build a few objects…a couch, the kitchen sink, a teddy bear - whatever - and put them inside the house. Then, when the house blows up, animate them flying out along with all the other pieces. The debris will look a little more interesting and varied, and it will also seem more like someone actually lived there, instead of it just being an empty model of a house.
Wow!
That is REALLY impressive!
As stated above, noone will notice intersections unless they go frame by frame and follow individual bits. This is especially true after you add motion blur and smoke.
Are the uniform bits roof tiles? if so, then they look fine… I’m trying to recall the actual footage of a house that happens to be a lot like this being nuked. I’m sure you’re using that as reference, It looks great… One question, in the motion are you having the inital heat blast, then the large boom that annihilates the place? If so, that’s great!
Keep up the great work!
Hi,
Thanks for all the input. I will definitely incorporate your suggestions. The symmetrical looks of the pieces on the roof were meant to be tiles, but I agree that they could be deformed some more. A secondary explosion would also help. The front porch is a mess, and will be redone.
I do hope to add the initial heat blast that torches the house. It
I have to say tho.. that will lOOK SWEET when it textured.
Ferreel-
Looks pretty awesome to me. Besides what the others have said I think the floor boards of the deck should crumple up into the walls, as they currently just nicely slide back through the house. But otherwise I think once some particle effects and such are put in it’ll look really really sweet.
Tellerve
