Definatly still rough, but its starting to come together? kinda working on everything at same time. Thnks Russ
Really nice job. I know it is a work in progress, but I would like to see some details on the sclera (white portion) of the eye. Stuff like small vessles and any tint that veries from pure white.
Thanks for sharing,
Urp
Apart from the eyes, I also think the nostril area need some attention. you might want to put a light with negative intensity inside the nostril or push the vertices inside the nostril further in and downward towards the mouth. The lips and the ears are very good.
cool, your model is well on its way. Aside fro mthe obvious(rest of the eye whits pigment map that im sure you just havnt gotten to yet) I think its a nice model. I would add some side burns or at least some stubble or poors in the place of them or top lip and chin area. plus i would add more volume in the hat. and slight bump in the lip area since few people I have seen have no definition in that area. It looks great though with great skin color . Keep up the good work.
“I put my faith in the power of my own mind.”
ICQ#58898276
Thank you all for your comments, Ill try them out and see what happens. Thanks much, russ
whats going on with the white line over his eye?? looks like makeup. also the skin looks a little plastic still. Proably needs a spec map and the spec widened and turned down a little. Great mod.
true.. a spec map will be a great idea to to break up the glossy look.
just a side note..
why does he look so scared?
ICQ#58898276
I mean great model great progress.
But exactly why are u depicting a black woman
in such a stereotypical and early america racist fashion.
Afriend of mine pointed me to your work and i was like wow the skin looks great … wait whuts with the scared, big eyed aunt jemima expression. I’m not knocking your 3d but this offends me and anyone who know whut this stands for.
why don’t u just color her lips radient red if this is what your aiming for. I dunno man corect me if im wrong.
I think its supposed to be a guy in a thin wool hat
ICQ#58898276
Wow, alot of posts. I think i should start with reponding to Say Hova first by saying there was definatly no racist intent in this image or the model or anything related to to the creation of this image.
“whuts with the scared, big eyed aunt jemima expression” Truth be told, because its still being worked on, the most interesting expression i could make without tweaking the geometry was to rotate the eyes, as if she was looking or about to look back. in fact i thought the look was more look she was eyeing the camera, but in retropect she does look scared. Any similarity she has to “stereotypical and early america racist fashion,” or any racist fashion at all is compleatly unintentioanal, and if this is the effect achieved i might have rethink the model, offensivness was not the point of the work. I choose to model a black woman for a couple of different reasons. The first being it was my best and easiest reference, since the model is based on my wife (we’ll get to the fact that many have thought the model was male in a sec…my wife is a beutiful woman,) and she is black. The other reason was the complexity of the skin color, which, im afraid, i dont quit think i have captured.
In all honestly im not quite sure how to responed to this, except to say that any racist intest was not intentional and i apoligise for offening you.
on the other points,
great i will expiriemnet with a specualar map!
hmmm yea the white line. This is the most texture intesive thing t i have worked on, and im still working out the details of projection maps. im pretty sure the next texture steop in relation to the white line in to break up the projection so i can edit the texture of each patch individually. (anyone have any thoughts on that, would that be one of the next steps?)
I would add some side burns or at least some stubble - heh heh, how embaresing! like i said it the most intensive texture exercise ive tackled, i guess i need to go back to the drawing board on that one. Although since reading all the post about the model being male, why rock the boat?
I also think the nostril area need some attention -
Yea thats the bit that bothers me the most as a piece geometry. must…tweak…more…
details on the sclera - most definatly.
thanks to everyone for their comments, i will post an update, soonish.
and again racism was not the intent. Russ
…Oh my gosh, Russ!! Im really sorry about my ass-umming that your model was a male. The lack of eyebrows, jaw volume, hat plus the lack of body or gendre oriented clothing reference had led me to that conclusion. “…Let’s say you are texturing a character front the front and back. You have two color maps for your shader. Choose the blend color utility node for your color and then connect the two projections to the two color inputs of the blend color node. Then take a third projection that is white and black and determines the transition between the two color projections are and connect to the blend/alpha input of the blend color node…gm”
for your projections. start by positioning your head in the front view and make it full screan, Then print screan. open photo shop and make transparrent layer and ctrl v(paste)yourprint screan. paint in black on the transparent layer your bump map. then on another layer paint your defuse map and on another any other passes you want. spec etc. hit ctrl alt s to save copies of your layers out and load them up in maya. oh yeah make them reall big to retain detail im map for any potential close ups since you can always make lower res versions though bumping up the res does not work… thats a rough way ofputing the process in a few words .
Keep up the good work, keep us posted.
ICQ#58898276
heh - That totally ok, not a big deal at all. The way it looks now it could definatly go either way, and really i kinda like the amidexterity (is that the right word?) since im not entirly sure what im going to use the model for yet. I just thought it was funny…
Yea the texturing method you decribe is pretty much exatly what i did, except i did front and side, instead of a back. I just need to go a tweak it some more. Thanks so much for your comments, their very valuable to me. peace, Russ
The term is “androgenous” hehe.
androgenous adj 1: relating to or exhibiting both female and male sex organs but with a predominantly female appearance 2: of or related to androgenesis
Ambidextrous is what I was born like and that is no affinity to left or right handedness.
am
Dear Hova, please, please - please stop smoking so much crack. Thank you…Dmitri. (You seem to be easily offended in the racial region, odd because you have no right to be. This is the 21st century my friend and you have no clue what it was like back then because you have never experienced it. )
Anyway, as for the model its good. The chin needs a little work and the lip line looks like it has a little drool on it. Too glossy?
Yo I think its great, if people get offended then let them. Obviously you werent trying for that effect and I still dont see any hint of rascism at all. You can make your model look however you want to man, if someone says “whats up with that?” tell them that if thats what they see then maybe thats what they wanna see.–Great job so far!!!
