Nurbs modeling cap nurb object
made curve, then closed, extruded it, so i have a shape somewhat like a tube. would like to close or cap both ends of the tube. tried duplicating the ends and applied planar but trimmed surfaces will not attach and untrimming does not attach the way i want it to.
Basically would like to cap an object. Anyway I can do this with nurbs? Thanks.
Yeah thats because nurbs dont realy work that way (in general you cant attach more coplicated surfaces). Using nurbs Pretty much requires you to know how they work.
There are few things you can do. One is to duplicate the edge and extude that to apoint and atach that. But in generay it ony works on simple objects. And yu can patch it (ahh alll the times ive spent properly patching a logo, a say poly is the way to go).
But untill you know how nurbs work i suggest you use polys, and subdivs.
NURBS= Not Understud Realy By Some?
Thanks for the info you probably would have took me months to realize subdiv is the way to go. But question, when you patch nurb surfaces do they become one continuous object. and is there a fix surface continuity feature in maya.
No they are separate surfaces but you stich them together with the various stiching tools, and in the end probably with global stich.
