I have two questions. I started my 3D studies by learning Softimage (the pre-XSI version) and am now studying Maya. There are two functions I loved in Softimage that I can’t figure out the equivalent for in Maya. Are these functions available?
Edit NURBS weight: In Softimage you can edit the “weight” of one or more control vertices of a NURBS object so that it becomes sharper or duller. For example, if you have a NURBS circle consisting of 4 vertices you can increase the weight of the vertices enough to turn the shape from a circle into a square or anything in between. This is different than making the nurbs object “linear” - The NURBS object is still cubic. This is especially useful for adding sharper detail to an area without increasing the number of isoparms.
Softimage has a funtion where you can select or deselect an entire row of vertices in U or V by clicking on a single vertex that’s part of the row you want to select. I found this TREMENDOUSLY useful, but I can’t figure out how to do it in Maya. The book “Mastering Maya 3.0” seems to mention the function, but doesn’t point out where it is.
Thanks in Advance! I’m a new visitor to high end 3D and I hope to become a valuable contributor from now on.
Yeah, I learnt with Softimage 3D also, and its modelling tools were far more sensible than that of Maya. Anyways, in answer to your questions…
Well, although Maya has built in surface editing function that effects nurbs weights, it is not all that controllable and can’t do rows of cv’s at a time. There are however a few scripts you can get here on highend3d that supply you with an almost identicles functionality to that of softimage nurbs weighting. Just look em up. They are really easy to use also.
Selecting rows…just select a hull…a hull is just that…a row of cv’s. You can also use your up/dpwn left/right keys to move between different hulls. Also, by the way, if after selecting a hull, you change to select by cv’s, you’ll notice your cv’s in the row are selected.
…and if you think those two things are the biggest problems with maya…since version 1 I might add and never fixed to date, how about the most useful modelling tool softt ever had that maya STILL doesn’t…PROPPER porportional modelling. Maya’s half-baked excuse is using artisan…not quite good enough I say. It has something it calls porportional modelling, but for anyone who is a soft user, you’ll know its not the same thing. You can do it via clusters, but thats not exactly practical now is it! I wish someone would make a script to use porportional modelling mode just like soft.
→ what is the built in surface editing function that does weighting that you mention pootang? not the surface edit tool? CV hardness?
→ i have always used the CVweight script, which only works surface CVs, but this thread prompted another look, and i find fjk’s weighting tool - allowing me to weight not just surfaces but crvs too. weightChange also. are these the only three scripts for weighting? are there any more?
→ always wondered why the weighting is lost on any further tweaks to a surface - why is this? esp more of a question now as a crv w weighted CVs does not pop back when you tweak its CVs …
→ lastly, are there any problems later in the pipe as a result of doing such weighting?
…what can I say, for anyone comming to Maya from softimage, the nurbs modelling support in maya is extremely poor. Its not really changed at all since maya1 beta 3. It needs despirate attention. All the good stuff from power animator has been put into and developed, in Alias Studio Tools. Personally, I prefer to model nurbs in xsi
