Nvidia Card with Maya 6
Hi all,
Right now I use maya 5 for linux and use the Suse 9.0 and nvidia driver (AGP) version 4496, if i use the version 5336, the camera panel on maya look blank. I plan to buy the maya 6 for linux, and i still doubt to use maya 6 because maybe it can happen again in maya 6 with nvidia driver version 5336. Maybe some body can tell me, that maya 6 supported the new nvidia driver or not?? i planning too, to use SuSE 9.1.
thank you for your attention.
Teddy
Maya 6 works just fine here with maya 6.0 with Gentoo, 2.6.4 kernel and the 53.41 drivers.
Try using the patched drivers from this page:
http://www.minion.de/
I’ve had problems with 53xx series of drivers. As far as I know, this isn’t a maya problem but a problem with the drivers. I’m using 4496 and everything works fine.
the 53.xx drivers from that page worked just fine on my machine. Do the 44.xx ones even work with the 2.6 kernel?
Yes, they work until version 2.6.5 of the kernel, after that, there are some patched drivers that are supposed to work, but didn’t for me.
I use 44xx series because at least for me they are much more stable, maybe depends on the card?, mine is a GeforceFX5600Ultra
The new 6106 drivers came out a few days ago. They support 4k stacks so you can use it with the newer 2.6.7+ kernels.
Yes, I still have to try them.
Someone in the gentoo forums made some benchmarks, glxgears and RTCW (a game), and 4496 are the best performing of all of them, so I wonder if there is another thing why I should update.
The only advantages are that I can use it with newer kernels and that it has a new and nice configuration utility, but I don’t know if it’s worth the trouble and the loss of performance.
What do you think?
