Am desperatly struggling to install my Nvidia graphics card on Debian serge,
Guys have mentioned different solutions to me I thank them one by one,
However in each approach Am facing a different error as follow:
Using official Installer from Nvidia:
No precompiled kernel interface was found to match your kernel . . .
As an other thread here knecht advised me to make a new kernel
" you get a list of available kernel-sources, choose the right one . . . ."
I am nost sure what is the right one , however there are:
kernel source 2.6.8
kernel patch 2.6.8
I got the source,
Extracted it ,
made a link
copied the standard configuration
made the kernel
At this point am not sure at all what are the setings, basically accepted them as default ones.
Hmmm , Well nothing is changed, Still am where I was.
Module assistant solution :
The only thing in module assitant that is about nvidia is nvidia kernel which at the end gets to
" installation of nvidia kernel source failed “”
When I search manually for Nvidia kernels I get nvidia-kernel-2.4.27-1-386
but when I ask to install it I get to
nvidia ke… … .. . DEPENDS: Nvidia-kernel-common , But it is not installable.
The final question is after I make a new kernel ( 2.6.8 ) isn’t it supposed to show this version when I use ( uname -r ) I am still getting the old one.
Any type of help and suggestion would be appreciated.
Thanks
