Nvidia Geforce 9600 Gt
I am thinking of buying a new computer with NVIDIA GeForce 9600 GT cards (2 in an SLI-capable mobo). Anyone have any experience with this new NVIDIA chipset, good or bad? I will be running Maya, Max, Photoshop and After-Effects mostly.
Here are the rest of the specs for the computer I want to buy:
Processor: core 2 quad q6600 2.4Ghz
Processor fan: Thermaltake CL-W0121 Bigwater 760i 2U Driver Bay Liquid Cooling System
motherboard: Abit IN9 32X-MAX
media reader: 21-1 media card reader
networking: D-Link DGE-530T GigaExpress 10/100/1000Mbps
firewire card: 1394 PCI FIREWIRE CARD
wireless card: Belkin F5D8001 N1 Wireless PCI
sound card: X-Fi XtremeGamer 7.1 24-bit
video card: 128MB onboard (I will be buying the GeForce cards separately)
optical drive: 20X LightScribe SATA DVDRW
hard drive: 500GB SATA 7200 RPM 32MB
power supply: Antec TruePower Quattro 1000 1000W
Case Fan: RCTIC COOLING Arctic Fan 12L
case: APEVIA X-Cruiser black
memory: GeIL DDR2-1066 8GB
operating system: Microsoft Windows XP Pro x64
Total: $2,167.78
Is it worth it to get the quad core processor? How about memory…I heard going over 4gb is a waste of money…is this true? DDR2 vs. DDR3? SLI? Liquid cooling? 1000 W power supply…is it enough? Too much?
Any comments, advice or experiences with any of this stuff (good or bad) would really be appreciated!
Thanks!!!
Since your going to run XP64 no over 4GB RAM isn’t a waste of money the more the better.
As for the quad a q6600 doesn’t cost much anyway so there’s no point saving 50 bucks or something and getting a dualcore instead since the extra cores will help alot with rendering if you don’t have a seperate machine to render.
Whats the timing on the RAM? DDR3 is better but it also is quite a bit more expensive and not worth it for the performance gain IMO.
No sure how maya goes with SLI but but if it has no problems with it then the two will run it fine though if your not going to play any games you’d still be better off with a quadro though it would cost a bit more.
Liquid cooling is only needed if your going to overclock the system which if it’s a business system then you wouldn’t be doing and if it isn’t then you shouldn’t be doing it unless you know what your doing.
You’d also be better off with 2 hard drives so you can put the swapfile on a seperate disc which will improve performance somewhat when it has to use it, could even go for a RAID setup for optimum speed for personal use is really not needed unless you really want the extra speed.
