how can we convert a obj to cloth and how do i make it collide with the body
select the object and then choose nCloth>Create nCloth
select the body and then choose nCloth>Create Passive
i did tht now the cloth is tearing to pieces....i created a tshirt obj and made it ncloth the body of the boy i made passive.
but now when i stimulate its sticking on the shlouders and rest of tshirt is tearing to pieces...its not retaining its shape.
sounds like the mesh you imported may no longer have all the faces joined.. if you select a face and translate it away from the mesh does it come apart or stay connected?
some sides of the face are connected to nearby faces and some are not at the edges
QUOTE(glassfairy @ 07/29/09, 09:44 AM) [snapback]312526[/snapback]some sides of the face are connected to nearby faces and some are not at the edges
is that before you made it nCloth?
yes...but i managed to join the faces...not when i stimulate it sdeformes and doesnt break..ohowever i wanted it to conform the body properly but it doesnt
