Object Inputs Channel Box Is Gone!
Hi
i have accidentally got rid of my inputs for the the selected object in the channel box. Normally when i select an object i can change its subdivisions and that but i cant anymore because i cant find the inputs. i would like to know how to restore it please... i have tried restoring default preferences Interface UI elements with the button down the bottom right hand corner but it didnt come back.
i am currently just using the create> poly primitives options to create the desired poly with divisions, its just more convinient with the inputs because i can change things after i have already made them.. Thanks
is it possible you have construction history turned off?
QUOTE(gmask @ 08/21/07, 02:51 AM) [snapback]271952[/snapback]
how do i know if its on or off??? i think its on though because i do delete history occasionally because its safer.
there is a little scroll icon with a tiny red parrot on it in the upper toolbar. If it's disabled it will have a red X through it.
QUOTE(gmask @ 08/21/07, 03:22 AM) [snapback]271958[/snapback]
dude u were right! thanks so much man inputs back to normal now. i must have disabled it when trying to make all those snap to things off
Thanks gmask!!!! I was quite frustrated with the same problem all afternoon.
I appreciate your post to this forum.
I was going thru training videos and my screen did not look like the tutorial screen and I was struggling to figure out where that INPUTS section went.
Again, I am grateful.
