I have an UI with three attrFieldSliderGrp elements and others but they are not important for this question. If the user clicks on an iconTextRadioButton the slider should change. This is a part of my code:
CODE #ask if 'rotateX' already exists if mc.attrFieldSliderGrp('rotateX',q=True,exists=True) == 1: mc.deleteUI('rotateX',control=True) mc.attrFieldSliderGrp('rotateX',min=min, max=max,at=joint+'.rx',p=self.controlLayoutName )
Maya enter this if request that shows that the attrFieldSliderGrp with the name 'rotateX' exists but when it should be deleted an error occurs "Object not found: rotateX". It is so weird I don't understand what happens?
There may be many rotateX named subnames just like in dag, so the names not uinique to deleteUI. So what you need to do is refeer to the full path name of the object
CODE if mc.attrFieldSliderGrp('characterUI|characterTab|imageLayout|controlLayout|rotateX',q=True,exists=True) == 1: mc.deleteUI('characterUI|characterTab|imageLayout|controlLayout|rotateX',controle=True) mc.attrFieldSliderGrp('rotateX',min=min, max=max,at=joint+'.rx',p='characterUI|characterTab|imageLayout|controlLayout')
but an attrFieldSliderGrp doesn't seem to be a controle. So this object was not found.
The right way to delete an attrFieldSliderGrp with deleteUI() is: CODE if mc.attrFieldSliderGrp('characterUI|characterTab|imageLayout|controlLayout|rotateX',q=True,exists=True) == 1: mc.deleteUI('characterUI|characterTab|imageLayout|controlLayout|rotateX') mc.attrFieldSliderGrp('rotateX',min=min, max=max,at=joint+'.rx',p='characterUI|characterTab|imageLayout|controlLayout')
QUOTE(beast0815 @ 01/15/09, 05:43 PM) [snapback]298940[/snapback] but an attrFieldSliderGrp doesn't seem to be a control. So this object was not found.
Yes its a layout that has all the controlls inside it, you can go inside it and delte the individual children if you wish.
