Object Size info, where?
Where can I find an object's CURRENT size info?
I can see in the Attributes window tab the ORIGINAL size and current SCALING info, but I can't find the CURRENT size.
For example, if I make a polyCube that is 8x8x8 and then scale it 50% (.5xyz) I should be able to find an info box that says its current size is 4x4x4, right? Please tell me yes!
The reason it came up is because I was making a simple staircase and wanted to create each step by Duplicating with multiple offsets for the remaining steps. Of course, the easiest way is to know exactly how tall the Master step is and offset the duplicates vertically by that amount. But if I've scaled or otherwise resized the Master step the offsets are disproportionate, so where can I find its current size?
Thanks!
No in general theres no such info... altough in your case you could read the bounding box scale!
Altough in your case snap and intelligent transform is even easier!
