Hi,
I plan to start a small business for 3D grafix and animation with two
other designers.
We have good Experience in using professional 3D software on WinNT
machines. We
Hi,
other designers.
machines. We
When you say second hand I’ll assume you have about an 8-10 thousand dollar computer budget for your work systems.
This money could be well spent on 4 workstations with dual CPU’s which would well outperform any origin or octanes you might buy off of ebay. Though I will say octanes do look pretty slick even by todays standards. Everytime I see one I wanna buy it.
you can probably check the test center database on this website to get an idea of what you should invest in. Its under the maya pulldown.
its fairly extensive and should have some more modern SGI hardware in it to compare to.
Very true Russell. There is no way that used SGI’s can compete with the price/performance ratio of a modern pc workstation. You can get an incredible bang for your buck today even if you don’t build them yourself.
Thanks for your replies
But what about Maya licensing for the workstations that only do net-render jobs?
Will I need a full Maya license for each render-computer?
Thanks
I THINK and i could be wrong here, someone with more experience in this area please comment… that if you are using the traditional Maya render license you get as many network clients as you want for free with your regular seat of Maya. Mental Ray however is a different barrel of monkeys and with that you pay per rendering node (computer slave).
Hope this helps…
close nuff
if your using the maya software batch renderer
you can contact your destributor for an unlimited number of render node licenses free of charge; provided you have at least 1 workstation license.
