DuplicateEdgesOptions; shows me the options window, as I had pressed the square sign in the menu. I would like to achieve if I press the hotkey, the DuplicateEdgesOptions should appear in the tool settings window on the right side (where the attributes editor and channel/layer editor window are, not in a floating window). When you press the move tool, the tool settings shows its properties, in case of 'offset edge loop' I can't achieve this kind of behaviour. Does it work anybody?
thank you
