Opencv and maya 64bit
Hi ,
Does anybody know if it's possible to use opencv with the 64bit version of maya?
Thanks!
Well this isnt a maya topic. But yes you can compile opencv for 64 bit, the windows version of 64 bit has some small limeitations however.
But really you can allways use a 32 bit version with a 64 bit maya torugh normal inetrprocess communication methods.
Thanks for the answer. Do you know where I can get more (easy to understand and non-visualstudio) information on how to compile it and what limitations there are? Or is there even a compiled version available? I couldn't find anything.
I don't have much experience with interprocess communication, but perhaps I should look into it.
Then your out of luck. Its not so much that compiling is hard, its not (just hitting f5), but setting the environ up is some work. But making a installer is a totally separate ballgame*. And there little or no interest usually to make installers for dev code, because people who need installers arent usually up to te task of using dev code. Also the licence on runtime libraries is a bit tricky too.
But the best you can hope for is asking for someone whos developping opencv and ask if they can do this for you.
  • making inatellers range form stupid waste of time to insane wast of time. I mean ive once done a program that needed a istaller. he program took 4 hours to write. The installer took a week to do (dont ask toatally idiotic thing).
thanks, joojaa! I'll figure something out...
