the only way to do a "sun halo" and "hot spot stars" is to render them in maya software and composite in an aditive layer later.
there's 2 problems thouigh:
the directional light handle (with sun shader) simulates sun position that comes from infinity and i need to use another point light for it's light glow only because directionals cant produce optical fx in Maya. if i place the point light at the center of the directional light, the optical halo of the point light and the sun dont match. so how can position the pointlight in a way so it always matches the sun position?
in real life, halo coming from hot spots on a car appears to rotate in our eye following the orientation of the surface and teh sun. in the optical fx attributes there is a rotation attribute but how can i map it in a way so it rotates natualy (like max's glare lume shader?
