Hi there,
I've been searching for 24 hours now and still can't make this working
Here's my problem:
I have this simple attribute:
outContraction = numericAttr.create("contractionOutput", "cu", MFnNumericData::kFloat, 1, &status);
MCheckStatus(status,"ERROR create contractionOutput");
numericAttr.setStorable(true);
numericAttr.setConnectable(true);
numericAttr.setArray(true); // Set this to be an array!
numericAttr.setUsesArrayDataBuilder(true); // Set this to be true also!
//numericAttr.setHidden(true);
status = addAttribute (outContraction);
//status = attributeAffects( outContraction, outputGeom ); (I've been playing with attributeAffects inside and out. It won't help !)
In the compute function, I'm filling in the number of items in array and modifying them.
FILL:
MArrayDataHandle outContractionArrayData = data.outputArrayValue( outContraction, &status );
MArrayDataBuilder outContractionArrayBuilder = outContractionArrayData.builder();
for (int i=0;i<restMPointVertexArray.length();i++){ // restMPointVertexArray.length() = number of vertex in the mesh
MDataHandle outContraction = outContractionArrayBuilder.addElement(i);
outContractionArrayData.set( outContractionArrayBuilder );
MODIFY: (simply adds 9 everywhere ! )
This code is in a loop that iterate over all vertex where i = current vertex
MArrayDataHandle outContractionArrayData = data.outputArrayValue ( outContraction, &status );
outContractionArrayData.jumpToElement ( i );
MDataHandle contractionOutput = outContractionArrayData.outputValue (&status);
contractionOutput.setFloat( 9 );
contractionWeightData.set( contractionWeightBuilder );
I can clearly see the data being updated in the attribute editor but if I connect this data to something else in maya, the connection will NEVER update ! I'll have to disconnect and reconnect it again to see it update ![]()
All the attributes change to 9 but the connection wont update. If I change them by hand, the connection will update.
Thank you !
