Can an animated paint effects stroke be rendered in Mental Ray?
for instance a stroke with tube animation, or applied to an animated hair system.
QUOTE(mrwolfy @ 06/18/09, 08:32 AM) [snapback]309713[/snapback]Can an animated paint effects stroke be rendered in Mental Ray?
Possibly, depends on a few things. Describe.
Specifically, I want to add a paint effects stroke, a glow stroke, to an animated hair curve.
Well In that case you use the exact same program that maya uses. Its not actually the renderer thst does the stroke in this case but post process prpgram that is the same as in maya software. So it works the same.
OK that makes sense... Maya software does not render paint effects either, so to speak.
