I am having a problem applying hair strokes onto a model. After completing a stroke, the location of the hair markers shift and reappear elsewhere on the model. What's happening? How do I fix it?
Paint effects onto a poly mesh require that you first have unique uvs defined for each point on the mesh. (A hidden curve on poly is created that is similar to a curve on surface, but currently you can't directly edit this curve on poly)
Duncan
