Add a attribute for rotation or the partoiilce rightclick on the object and choose paint particle and whatever material you have.
NOTE its NOT very intuitive to pint in direection with attribute paint tool! THe way fur works is TOTALY different here. Anyway you could do that but its painfull to set up.
Personaly i wouldnt do it thisway at ll but hey its your tool Personly id just paint soem diplacemnt on the object and then export this out as a normalspace bump map and read it in using artisan then make something meaninfull f that instead.
QUOTE(Joojaa @ 05/20/06, 05:35 AM) [snapback]237752[/snapback] Add a attribute for rotation or the partoiilce rightclick on the object and choose paint particle and whatever material you have.
NOTE its NOT very intuitive to pint in direection with attribute paint tool! THe way fur works is TOTALY different here. Anyway you could do that but its painfull to set up. Personaly i wouldnt do it thisway at ll but hey its your tool Personly id just paint soem diplacemnt on the object and then export this out as a normalspace bump map and read it in using artisan then make something meaninfull f that instead.
