Paint Skin Weights Tool (2)
This is driving me crazy..
I just did a smooth bind for a biped character, and now his arms are pulling away parts from his torso when you pull the arm away from the body. So I’m going in to Skin>Edit Smooth Skin>Paint Skin Weights Tool and setting the weights Value to 0.00 so that where I paint, it causes the area to not be influenced by the joint.
So I’ll start with the LeftArm, paint the white area on his ribs black, then I’ll select his LeftForeArm and paint the new white area black. Then on down to his LeftForeArmRoll, and then LeftHand, all the way down to his finger tips, painting his ribs from white to black all the way down. But then I rotate the top joint, and it’s still pulling his ribs out. So I click on LeftArm again in the paint skin weights tool window, and his ribs are white again! So I paint them black, then the forearm, paint it again, and over and over again I go. I paint it, but then when I click on it again, it’s back to white, and my ribs are still being pulled out when I rotate out the arm. What do I do? This Paint tool doesn’t seem to be working at all. Anyone have any ideas? Thanks a ton!!
Brian.,
Once you have paintted a influence for a joint hold its result by clicking the hold button. Otherwise it will start to flood the extra values to the joint because the sum must be 1 and the extra values must go somewhere.
In thi sisnese iet much better to paint 1 what you want included than what you do not want.
You can paint in abstract to values if you wish by unchekking normalize values this may seem more intuitive to you. But it will soon not be. Since setting the value to 0 ON all joints crumples the result to oblivion. So what your mind may feel better is to make one extra joint (usually tough yuou let the extra flood to your root joint which represents no movement), hold all others and let the surplus flow into that joint by holding the rest then at the end of the job delete that joint. Once youve delegated all 1 values of it somewhere sane (all fractions will be rounded off).
I have had the same problem I think i ended up doing something simmilar but I forget what that was now. I have herd rigging tools in XSI are way more intuitive and easier to use, especially it seems to give a specific color for each joint weight. I’m about ready to start some tests for character animation and will need to rig several characters… which Im wondering if there is any better method to paint the weights in maya. It seems as thought this system has not been updated for quite a long time and wondering if there is a more “modern” technique other than paint joint holdweight, paint joint holdweight and have all your weights flood to the other joints and somehow pray that it all comes out allright?
Have you tried using “Replace” instead of “Add” [under the Paint Weights section] and changing the value to 0? I believe this is one way to reverse the influence, so it becomes black.
yes, but the weight has to go somewhere so it usually just dumps the weight to another nearing joint, but sometimes it will throw the weight to joints really in a chaotic manner some joint influence far away. I guess as you paint a weight down to zero the weight “has to go somewhere” so it adds to another joint as you paint one joint down. Its just a bit of a tedious process locking the joints one by one and painting them.. but i guess thats life.
You can also use the Component Editor for managing skin weights. (Window > General Editors > Component Editor).
Select the vertices you want to edit, then open up the editor and navigate to the “smooth skins” tab. You’ll see a chart of the selected vertices plotted against the joints that influence them. The cells contain the value of the weighting. You can use this to edit weights precisely and really force them to do what you want. Sometimes when the Paint Weights Tool isn’t doing what you want, this is the best way.
It’s especially good for cleaning up strays (those pesky vertices that wind up weighted to a random joint elsewhere in the rig). Just select the culprit cells and assign them all a value of 0.
yea thanks for the tip.. Ill try that next time i have rouge verts running away. I do wish that the artisan tools were updated to work a bit more intuitively perhaps. It seems that the artisan tools date way back and haven’t really improved much. I guess there is really no way around it. weighting can be a tedious process.
I’ve got the same problem, and it doesn’t matter if the weights are on hold or not.
The feet of my character come really close, and they are influencing each other.
So I flooded each foot with a zero value from the joints I don’t want, then put a 1 value with the ones I do want.
But when I move the foot, the verts still stay.
I’ve also painted the weights while the foot is in a test position (where the verts are way out of line) and when I paint a 1 value on them, they don’t even move.
THe only time I could get them to stick is in the component editor, but I couldn’t set the values directly.
First I had to attempt to zero all the values first, then it would allow me to enter my own weights manually.
Before I try to zero the weights, if I tried to enter a value, it would just spread the weights evenly across all of the joints.
I get the feeling that this might be a glitch.
When I bound the skin, I unchecked maintain max influences
COuld this be the problem? I assumed that this unchecked would allow me more control over the weights without redistributing them elsewhere.
