get a different driver (different means just that, newest does not equal to best possible you see). If your display card is in the certified list, any problems associated to that card is listed, and appropriate measures and counter works are there (and if after reading that theres still no fix for the card contact support). If your card is not on the list, or explicitly not supported then your on your own, sorry ( just keep testing different versions. Even contacting support is not likely to help you in nay way, they will just reiterate we told you so). If its e newer generation workstation card then it will eventually probably be certified.
