After I envolop the object , i go edit weight. and i use a brush to paint, but how to adjust the pressure of the brush. I don't want to give 100% weight to a bone. and i want to paint gradually. How do I change the pressure of a brush.
opacity?
I don't really know if it is opacity. I've try to change it, but it doesn't seem doing anything. I want to have let say 5% each click for the weight instead of 100% each click all the time. do you know what i mean?
It should work just changing the opacity of the brush in the weight paint property box (ctrl+w). Then you change between using the envelope weights box (ctrl+e). Or try asking speye_21. If he's not too busy defending XSI in the Maya General forum .
Thanks ivanp. I've to crank down the opacity into 0.1 to get my effect. This is really what i want now, i get the idea. Thank you very much
