QUOTE(tharmine @ 09/22/05, 12:54 AM)
well, thank you guys. I tried everything you mentioned : uninstall the mouse driver, assign the maya application in the wacom pref to use the center button to my stylus, delet my maya prefs. The middle mouse button of my mouse was working because it was assigned to double-clik and it was ok. I still have to try your suggestion silk about the mEvent class to see if anything is being picked up at all. Otherwise, it will remain a big and annoying mystery.
thank you anyway.
[snapback]215390[/snapback]
Be sure to check your Logitech Driver Settings (It'll usually set it's own context menu as the Middle mouse button, but change it to "Autoscroll", which is the middle Mouse button that Maya recognizes).
-and, check your mouse properties within Window's Control Panel (sometimes it'll use one over the other [never underestimate the stupidity that is Microsoft's Windows])
-J
