Parent And Child Movement Control
I want to parent an object to a joint. When I rotate the joint, I want the parented object to move in a certain direction. My problem is that I am able to make the parented object move the way I want it to but I cant control the amount of movement. When I rotate the joint, the parented object flies way off the joint but I don’t want that. Thanks in advance.
Instead of parent the obj under the joint, you can control the rotations of the obj via the rotations of the joint using the connection editor; to simulate the parent behaviuor be sure that the joint has the same local orientation axis of the obj and the obj pivot has to be placed in the joint position. At this point you can use a multiply divide node between the joint and the obj to control how much the obj follows the joint’s rotation (I attached a sample scene…)
I hope this can help
http://www.francesco-puccini.it/test.rar
