Particles and mr Volume shader
I’m trying to render some particle effects with mr (fire + flow), and I realised (also confirmed by some threads here and by the Maya documentation) that Maya isn’t able to translate complex particle systems, therefore crashing during rendering.
I was then wondering if there is a way to get particles rendered in mr for Maya, so I tried to apply the built-in mr volume shader (mib_volume) to the particle’s shading group (connecting it to the mi volume shader port), overriding the Maya particle cloud shader.
I don’t have any idea of how getting it to work. If I render the particles with the mr volume shader suppressing the Maya shaders, I get a black block where the particles should be. If I don’t suppress the Maya shaders, I get very weird results.
I didn’t find any tutorial about it, except the ones in motiondesign.biz. But they are for volume scattering, and I just need to render particles without scattering.
As a desperate solution I could composite the scene rendering the geometry in mr with a fake light and the particles with Maya, but it would be hard to achieve a realistic lighting and global illuminaton.
Any help is highly appreciated.
gm
