Particular Setting For Rla Files?
I have render RLA (with z-depth) file from 3D max, and FileIn the sequence into Shake.
On 3D max, the Z-depth shows as back and white gradient-ish information, however, shake shows as just black and white (no gradients).
I did resarch a bit and someone was suggesting openEXR is better format to use in Shake, so I tried that... however, now z-depth shows as all black,...
Now, I'm wondering if there is any setting that need to be done before you export as RLA and openEXR?? (they were rendered as 16bit).
any suggestion will appriciate!
Thanks
