Particules and pond
Hi all,
I would like to create a fall of water. but as know I can’t make collide the particules with the pond I created. I would like to know I could do to make the effecte without collision…
Thanks in advance
GPhoenix
hi there
As if I am not mistaken you are trying to make the effect of having rain on the pond.
In this case you can :
Make a particle system as rain fall
Add a radial field to the particle and make it as the source of the field and make sure you turn on the apply per vertex option.
Then make your pond surface as a soft body and connect the field to the softbody and twick the settings.
Best
Yes you did understand what I would like to make but I don’t manage to do it.
Here is how I do you 'll can correct me…:
-create emitter
-apply a gravity field to the particules
-create a radius field without connecting it to anything
-with both particules and the radius field selected (the field first so it works) i use the command “Use selected as source of field”
-change setting of the fiels and put “apply to vertex” on
-Then I create the pond
I use the command to make the pond Soft(“create soft body”)
-I select the pond and the radius field and I use the command “affect selected object”
When i launch the animation it doesn’t do what i want:
I can see the particules going down but nothing happens when it touch the pond … it just go trough as if there were nothing…
I don’t understand where is my mistake.
Thank you
Hi
The way you are doing it exactly how it shoud be .
I just did it based on what you wrote and it works it just needs to be etwicked .
By the way don’t forget to add another object like the pond as the goal for softbody other wise it will leave its place.
I hope this will work .
hi,
What do you mean by etwicked(sorry I’m french and i unfortunatly don’t understand every words).
And how can I “add another object like the pond as the goal for softbody” , do means to make a duplicate?
If not what should I do?
Thanks again for your help
Hi
I meant twick .
Any way Yes when you make your soft body you have an option to make a copy of the object and make it as a gola .
Any how you can later duplicate your object and remove soft bodis from the copy and make it the goal for main object.
hope it works
Hi,
ok I still have a probleme : when I select the “duplicate, make the original soft” option in the “make soft-body” tool maya tells me that the pond is not a good object and that I can’t use the tools with it… But when I just ask to make soft(without copy) it works…
Can you tell the ‘exact’ way to make the pond soft and make “collide” it with the field…
Thanks
Hi
What do you mean by a good objetc ?
Any way This is the procedure :
Make an Object ( a NURBS plane )
Width : 20
Patches U,V = 50
Go to make aoft body :
Duplicate Make Original Soft
( Hide none soft Object )
( Make none Soft Goal )
( have in your mind that as I see maya has a bug that sometimes the creat BUTOON doesn’t work and you should use apply or vise versa )
Make an omni emmiter and move it up the surface
make a gravity and connect it to the particles
if needed make the emitter faster ( perhaps 5 )
while nothing selected make a radial field and make the Magnitude 3
Connect the radial field to the particles of the surface using affect selected object
select the Emitter Particles and then the radial and choos use as the source of the field .
Select the field and go to attribute editor and in special effects switch on the Apply per vertex.
Play your animation .
Bye=;
