I thought this would be a simple exercise but apparently not.
consider the following:
I am trying to pass dimensions to a matrix
int $a = 3;
int $b = 4;
matrix $foo[$a][$b];
it seems straightforward but it gives me a syntax error.
I tried a more round about approach:
int $a = 3;
int $b = 4;
string $bar = ("matrix $foo[" + $a + "][" + $b +"]";
eval ($bar);
This works fine interactively but when I source the script it says $foo is an undeclared variable
The intention is to capture [frame][particle] id for some file translation. I know it is possible with arrays. But it can be cumbersome. The problem is that matrices need an explicit declaration of dimension. I want to be able to pass ($start-$end) and (particle.count) to the declaration.
Any thoughts?
thanks
cl
