I am trying to apply a pic sequence as a 2d local texture map. I select sequence in the dialog box and in the picture file I select my sequence of pics, but all it shows is a question mark. Is there something I'm missing?
check whether the sequence pictures r in the pictures directory of ur default database, if not copy them there, am sure this will solve ur problem..
viva ala softy
Also check to see if your image numbers match your frame numbers. If your images go from 200 to 400 and your animation only goes from 1 to 50 then you'll never see your pics. (Because your animation never makes it to 200.)
Edhttp://www.EdHarriss.comhttp://www.EdHarriss.com
