Picture as weight map?
Is it possible to use a texture as a weight map and how do I do it?
As far as I know, it,s not included as a prepared operator. but I think it should be possible with a scripted operator.
I’ sure I could not help. Sorry. I also had the same problem but I did not get an solution for this ( not yet)
If you have a solution it would be great if you share it.
Sanostol
Yes, for certain things. It really depends on what you’re hoping to do with the weight map. (It can be used to control particle emission partameters, for example) I’m not in front of XSI at the moment, but the work flow is pretty simple.
Create a Texture Map (as opposed to a Texture Projection) The Texture Map can use any of the default projections, or can reference a projection you’ve already created. Assign an image and that’s it. Now you can assign the Texture Map to the parameter you want to control via the parameter’s connection widget. Hope this helps!
Dave Shirk
Quiet Man
very quite indeed…
i’ll have to get you to show me that one tommorrow, i am yet to find a parameter that will accept textures in place of weightmaps.
excellent.
