Pixelanalyser
Hi Folks,
Hope you can help out this Shake newbie...I'm probably asking something that's
either obvious or impossible...
I've used a PixelAnalyser node on a clip that has changes in
luminance level over five hundred frames and have saved the result of the analysis.
How do I then apply this analysis to control another node, say ContrastLum for example?
Thanks in advance for any suggestions.
Halfmedley
you should look up "Linking Parameters" in the manual.
To get you started, here is script that uses PixelAnalyzer to form a rudimentary flicker fixer:
Color1 = Color(720, 486, 4, .8-(sin(time)/5), .8-(sin(time)/5),
.8-(sin(time)/5), 1, 0);
Mult1 = Mult(Color1, (1/pa1.area1AverageRed), (1/pa1.area1AverageGreen),
(1/pa1.area1AverageBlue), 1, 1);
pa1 = PixelAnalyzer(Color1, "1", 1, "area1", 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, width/2, height/2, 30, 30, 1);
Exposure_comp = Mult(Mult1, 1, 1, 1, 1, 1);
Replace Color1 with your image. Mult1 mulitplies the image with the inverse of the PixelAnalyzer (pa1)
Set Exposure_comp to the color you want the area you are analyzing to be stabilized to.
