Hello All!
I have encountered a problem that I am unsure of how to solve. I am looking to animate a flexible, corrugated plastic tube, the kind that is used to bundle and protect groups of wires.
Example: The black bendy tube in the picture above
I modeled it in poly’s, as separate geometry from the camera and the stand. I would like to rotate the camera and have the tubing bend a little to follow it. The thing is I am unsure how to do this properly. I can make bones, smooth bind it, and then put an IkRPsolver handle on them to control them. Then I parent the handle to the camera body and when I rotate the camera the tubing moves along with it. I am only rotating the camera in one axis, left to right (y axis) and it only rotates a little bit before the end of the tube that is in the stand pokes out. The bones are in the z-axis, or up and down for the camera.
Basically, I would like it so that the ends of the tube stayed oriented in the same direction of their respective connections, so the end of the tube isn’t poking through the geometry. How can I solve this? Careful painting of the weights? Pole contraints? Can I do this for both ends? Should I redo this with hair dynamics like a phone cord?
I would like to keep the geo I have now if possible. I’m still learning this all, so as much help as you could give would be awesome.
Thanks for your help!
-Sam
