make sure you turn off your frame/title/action safe boxes and that your camera view is the only view open, then click the use render setting box (or specify your own settings in the custom field). Also, you can't playblast an area bigger than your viewport. So for example if you want a 1920 x 1080 output but your screen area only goes up to 1600 x 1200... you're out of luck.
