I would like to know what I can do to improve the look of these. I am pretty satisfied but I am a perfectionist and I always appreciate constructive critisism. I am mainly concerned with advice on the texture, I through the model together really quickly.
By the way I model and rendered the layers using max 5.1 and used photoshop to composite the layers together. I eventually plan to do the same technique using an animation and combustion 2.
It would help if the threads were less rounded and if they looked like they were blended into the the body more. Right now they look too much like a seperate object.
I know, the model sucks, but not bad for only a 2 minute effort. My main concern is the texture. This was a project for school and the teacher didn’t want a highly detailed model, just a good texture. I plan to redo the process on my own time with a higher detail screw and hopfully animate it.
I know you are only concerned with the texture, but the threads should touch each other. If you do that, on the finished model, then your texture will not show so well. Regardless it’s a nice texture. Good job.
I know this is way off the subject, but if you think about it, most everyone knows that the threads on a screw form an incline plane. Most people don’t know why an incline plane makes it easier to do work, but most people will say the longer your incline plane is to the height you are lifting the object, the easier the work is (ie: Mechanical Advantage)…
…so, wouldn’t it make since to design a screw with as many threads as you could cram on it, so it’s incline plane is longer thus making the work it does for us easier? So, the threads should touch.
