http://www.google.com/search?hl=en&q=n...G=Google+Search
It can be any of the problems indicated on the above links ... but it's most likely an nVidia problem (are you using the nVidia firewall ?)
You should be able to access the config. from the control panel. Just test if the problem stay after removing the firewall service. Also make sure you're using the proper drivers.
Hope it helps,
Guyb.
Description: File nSvcIp.exe is located in a subfolder of "C:\Program Files". Known file sizes on Windows XP are 110653 bytes (30% of all occurrence), 131136 bytes, 106557 bytes, 131133 bytes, 110658 bytes, 90173 bytes, 118848 bytes, 118843 bytes.
The program is not visible. nSvcIp.exe is not a Windows core file. The process can be removed using the control panel Add\Remove programs applet. It is a file without information about the maker of this file. Therefore the technical security rating is 36% dangerous, however also read the users reviews.
Important: Some malware camouflage themselves as nSvcIp.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the nSvcIp.exe process on your pc whether it is pest.
Part of the NVIDIA Firewall, which is used in the Asus A8N-E Motherboard ....
