Hey guys-
is there a way to add more inputs to the Plus/Minus average node? It seems like there ought to be a way to do this, otherwise this node is usless. I know I have used this node before, but can't seem to get it workin now. Thanks
Scott
sure the input is a array! If you use the gui the righclick the originator node choose waht you want to pull out then go and rightclick teh plusminus average and then choose the next empty connector taht it brings up for you the connection editor is a bit useless here.
