I thought i saw this here once before but now I can't find it.
In previous versions of Maya, I was able to select a range of CVs, highlight one of the axis manipulators and snap all points to a grid line, to line them up. In 4.5, the snap seems to average the position of all the points.
Is there a way to override this, to return to the earlier functionality? I can't think of a reason I'd want to use it the way that it is.
Double click on the move tool and reset it to its default settings. Make sure that you then toggle off the new "Retain Component Spacing" feature.
Hope this helps,
Randy Stebbing
Thanks, Randy -
sometimes the simplest answers are the most elegant. I just did that and came back to answer my own question - DOH!
David
An easier and faster way to do it would be to hold down W and LMB then a marking menu of the Move Tool's options appear, and Keep Spacing will do it. I love 4.5's new marking menus
