Poly Smooth problem?
Hi,
Ive built a low res poly object, but it is made up of seperate poly objects, I have combined the poly's and merged vertices. Now when I do a polygon smooth, certain vertices are pointy and its as if there are still come parts that arent all that smooth, these places are all where the different poly objects where merged. Please if anyone knows how to prevent this let me know. Thanks.
Loked
Did you actually merge those edges or just do a combine?
Hi,
I merged the vertices, not the edges, I always seem to have trouble with the merge edges tool, so if I do need to do this, please just explain to me how. Thanks for the quick reply.
You seelct one edge and then click again to merge them. It will highlight the edges that can be merged. I think you may want to get the 4.02 upgrade as there was a bug that caused Maya to exit. YOu will also want to minimize the numbe or undos while doing this as well.
Hi,
I tried that, but I still have the same problem, when I smooth it out its jagged. That sounds like the right root, cause when I show borders, the borders are right where it lets me merge vertices. Perhaps I can give you the scene file and you can check it for yourself.
