I'm using maya 8.0 ULTD and I have just finished a model using subds.
I am trying to setup poly wrap deformers, but when I convert the subd model to polys, the new poly is still connected to the original.
In the settings for conversion, I have it set to vertices, show original, and share UV's is checked(I've tried it unchecked, but no difference)
The tutorial I'm watching shows him convert it, and then immediately moving the poly mesh off the subd without the subd attached to it.
When I assign the new poly mesh to a layer, then make the layer invisible, it hides the subd as well, but when I make the subd layer(made before the conversion) invisible, I can see it disappear inside the poly.
Any reason why this is happening?
thanks in advance
virtual_gravity
