Polygon sculpt tool
when trying to use the smooth feature with the polygon sculpt tool, sometimes the geometry gets rounded, other times it begins to separate. is there any easy way to keep smoothing a lofted object to remove hard edges without creating gaps in the mesh?
You need to merge edges first
knew there was an easy way! - thx
is there any way to have edges automatically merged when lofting?
Nope.. The only way you might beable to do it is to make a planar surface and then extrude the faces.
