Polys dissapear after UNION ?!?!?
HI,
I’m trying to Booleans/Union two polygon objects and they dissapear after operation. Of course both objects are in some advanced stage.
It happened before but I figured that after Combining mirrored parts Vertices are doubled in mirror axis line and Combined objects dissapear after Union later on.
Merge Vertices after Combine was the answer so far.
This time not
Please take a look at this file and tell me whats the cause for that.
http://www.nellmultimedia.com/unionbug.zip
thanks!
Vertices 430 and 234 of the upper part are positioned in a way that they form a flipped face. Pull them apart and create additional triangle there. After that, it will work peachy.
Inctroductory lecture on poly booleans will be given to you here by joojaa, soon
Anyway I’d never boolean those two parts because it’ll produce some dirty topology which is not what you normaly want. Especially if you intend to animate. Instead, stich the parts togeter by first deleting the capping edges, then combinig them and then construct connector faces using append to poly tool.
fantastic
by the way, how did you find it? I don’t think you’re looking all over the model. Is there some command that checks for any ‘abnormal’ geometry structure?
And ofcourse there’s a bit mess after union but I clean it up pretty fast to line up everything.
As you see top part was created with head, torso and arm separatly, now looks like one piece of ‘wood’
I just closely look at the intersecting areas of both meshes. This thing is pretty visible if you turn edge display on.
There is a poly cleanup tool which can help in some cases ( Polygons->Cleanup ( options ) ) and of course custom poly display which can reval a lot about bad meshes.
However, you should adjust your modeling workflow so you don’t end up with situations like this ( bad faces you don’t know about ). Always try to have absolute control over your mesh state.
I also suggest you look at the maya faq at this forum. “Dissapearing booleans” is a very frequent question. All of the common problems people have with booleans are covered there.
ofcourse, thanks.
