polySplit - bug? feature?
So -
I made a melscript to split a facerow, but that sub-rutin, which contains the polySplit command, and the selection parts occurs some problem.
If i run this sub-rutin in the script editor a few times, there arent any problem - BUT, if i put this sub-rutin in a for-loop, it sais error.
More exactly, it sais a warning : Warning: Can't perform polySplit11 on disabled selection
I think, its a bug, because if i run the polySplit command, sometimes happens interesting things (the select -cl; doesnt work, and unselected edges (etc) will be selected if i select an other edge).
So, does the polySplit command work at anyone, in a FOR-LOOP ???!!!
thx
andris
bandee@k2.jozsef.kando.hu
before calling this a bug send your code so others can look at the way you are calling the command to see if someone can help.
