QUOTE(GlennJ @ 02/03/07, 04:38 AM) [snapback]258805[/snapback]
- File in an 8 bit uncompressed quicktime to shake
- File out in the same format
I compared the input and output just to see if going thru shake introduced any change, and found that shake is clamping down any luminance values greater than 100. There are some areas of the source footage that are a little hot, but I like the look, and the clamped footage coming back in looks a little unnatural. Nothing I've tried in shake has any effect.
Any ideas on how to prevent shake from doing that?
this has been discussed quite a bit both on the forum and the list and gavin from the shake team confirmed that there is nothing you can do about it because quicktime handles the conversion (and clamping) on the filein, so shake has no way to acess the superwhite values.
one workaround i used is to use a color corrector in fcp, then export, and reverse the color correction in shake or later in fcp.
++ christoph ++
