I may have found a fix for the common overlay problems with artisan type tools. I found this using the paint textures tool under the Lighting/Shading menu of Maya 3.0, but it most likely applies to other tools as well.
In the Display Tab there is the option to turn off Draw Outline. Doing so gets rid of the red circle that shows your brush size. On my machine, Dual P3 500s, 256ram, Origional Geforce, this red circle seems to be a cause of slowdown in interactivity. Not knowing what overlays are exactly, this may or may not be related, but is worth noting. If this works for you, remember you can always adjust your brush size with the outline on, and then turn it off when painting to get best performance.
Unfortunately I was unable to see if this method would work with Paint FX because the outline option simply isn’t available. Though there might be a way to access this through the actual paintfx script/code. Haven’t looked yet.
Please post any relevant info you may have regarding the little red circle of slowness
specifically if this is actually an overlay issue. What overlays exactly are would be nice to know as well.
Hope this helps and thanx to all who reply
~Garry
