Hi,
It is possible to precalculate a final gather map by setting FGMap rebuild setting to Off, then render one frame, then set FGMap rebuild to Freeze and it will reuse that map.
This is great for a single frame, but when trying to precalculate FG for an animation (Camera moves only), is there anyway to precalulate the FG for every say 10th frame to a single map? - I am currently doing this manually by stepping forward 10 frames, rendering with rebuild off, then stepping forward 10frames, and so on. u can see the problem with this if the animation is 1000s frames…
What am i missing?
using Maya8&mentalray.
Thanks
Kareem
